Starting up cold
Old 03-07-2012, 07:25 PM
rfomlover
rfomlover's Avatar
Smile Starting up cold
Out of curiosity since I am learning about how engines run, if you start a car up cold, particularly the 4V 4.6Ls, let it run for about 20 seconds or so, then shut it off, does fuel pool around the cylinders since the car was running rich? And if you leave it off after a quick cold start, can it smell really bad like a burning smell, more powerful a smell than rich fuel when turned back on since that previous fuel is getting burned with another rich mixture? Thanks!
rfomlover is offline
Old 03-08-2012, 03:18 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
All of what you postulate is possible, and it would be far from the best thing to do to an engine on a regular basis--there is also no reason I can think of for ever doing so, making the questions largely irrelevant...
cliffyk is offline
Old 03-08-2012, 03:31 PM
Shampue
Shampue's Avatar
I guess you could start the car in the garage, back it out to the driveway to wash it and shut it down in under 20 seconds.
Shampue is offline
Old 03-08-2012, 04:57 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I wouldn't, in fact I even have SWMBO trained to not do that--no small feat...
cliffyk is offline
Old 03-08-2012, 05:28 PM
rfomlover
rfomlover's Avatar
It was when I put the stock tune back on it started for about 20 seconds an shut it off to make sure it still started. The next day that weird smell came from it upon startup. it's an 03 cobra.
2007StangV6
01-28-2016 06:09 PM
StalkerGT
09-25-2015 02:41 PM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Starting up cold
