RELAY HELP!!??FOR NITROUS
Ok my question is which number goes to my solenoids and which goes to my throttle activation switch and which goes to the non fused 12v since it looked like 30 is fused 12v from my battery
Looking at their diagram, I would say that Post#1 is 85, Post#2 is 86, Post#3 is 87, and Post#5 is 30. Personally I would probably also fuse the 12V going to Post#2 with maybe a 10A fuse or by wiring it through an accy position on the fuse box.
So in other words... the blue wires from the electronic box go to 85, the solenoids are wired to 87, the heavy fused wire goes to 30 and 86 just goes to an accy port on the fuse box.
If you want, I can give you a detailed breakdown of the how this circuit works, but I will leave that for another post if you are interested.
Seanam
Oct 4, 2015 10:15 AM
schecterplayer
Sep 23, 2015 08:38 AM
