Left Rear lower Than Right.
Old Sep 18, 2005 | 11:53 PM
*Blk_96_Stang_GT*'s Avatar
*Blk_96_Stang_GT*
Default Left Rear lower Than Right.
The left rear wheel is about 2inches lower than the right side. Is this bad shocks? or somthing else?
Old Sep 19, 2005 | 12:00 AM
02StanGT's Avatar
02StanGT
Default RE: Left Rear lower Than Right.
If your wheel is lower than the other, you are on an incline . If the wheel wells are uneven, it's probably your springs. Has it been lowered?
Old Sep 19, 2005 | 12:03 AM
*Blk_96_Stang_GT*
There is about a 2in difference between the wheel and the wheel well...car hasnt been lowered just 3:73 's
Old Sep 19, 2005 | 12:11 AM
02StanGT's Avatar
02StanGT
You are sitting on a level surface, right? If so, like I said it's probably your springs.
Old Sep 19, 2005 | 12:17 AM
*Blk_96_Stang_GT*
its not perfectly flat, but its not a 60degree angle. i got a really flat drive way. and i notice it everywhere i go.
Old Sep 21, 2005 | 08:54 PM
LazrRd00GT's Avatar
LazrRd00GT
push down on the car on both sides and if it continues to bouce when you let off, then it is probobly your shocks, you can also check around the shocks to see if any fluid has leaked around the outside of the shocks, if so, then its your shocks, but if not, then it could be your springs or spring isolaters.
Old Sep 22, 2005 | 01:28 AM
Jglisson's Avatar
Jglisson
Some fat *** owned the car before you did?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Dragonus18
Sep 9, 2015 01:21 AM
Jose Corretjer
Sep 8, 2015 06:32 AM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
