Battery Light
Battery Light
Hey, I have a 2003 GT and at times when i'm driving the battery light will come on for like 2 mins and then just go off. Sometimes it doesn't go on at all when im driving. I got my alternator tested and it was fine. What is it? Nothing?
The lamp comes on when the system voltage drops below 13V with the engine running. This could be a wiring problem:
Or a problem with the battery or generator (I realise you said the generator had been tested--it may nonetheless be defective depending on what tests were performed).
Here are some documents from the shop manual that will help you sort things out:
Charging system component tests procedure;
Charging system diagnostic procedures;
Charging system wiring diagram;
- the heavy black/orange charging lead from the generator to the battery;
- the heavy ground wire from the battery to the block, just aft of the oil filter;
- one or both terminals at the battery;
logan409
09-26-2015 07:43 PM
09-25-2015 09:06 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
