Help!! Overheating?
So driving my 2003 Mach the a/c stop blowing cold air.. Shortley after my temputure guage starts to get hot.. What could this problem be? I also thought I saw white smoke coming out my tailpipes first time it happend.. Only happened twice.. Last 2 times I drove it.. Help please! Thank you!
first cool the car off and check your fluid levels.
second. check your thermostat for malfunction, or replace it, its cheap anyway
Run the car with the AC on and inspect to see the fans are turning on as they should.
see if it gets hot with the AC off. The fans SHOULD turn on sooner than usual with the AC on.
if anything else you may have a clog in your coolant system. drain and refill just to be sure. also if your car gets hot pull over and shut it off. DO NOT drive with the car hot, you can warp the heads and/or crack the block, this happened to me.
let us know.
let us know.
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
