How to adjust clutch pedal?
[QUOTE=motorman524;7987356]So do you actually have a firewall adjuster? That was never made clear. If not, that's what you need to be adjusting with.[/QUOTE
No I do not have a firewall adjuster. But I don't get how that is goin to make the cable shorter for it to be tighter. It's just really loose where the clutch for is and its adjusted all the way as tight as it will go and still is loose
Is a firewall adjuster going to fix that??
junior04
09-28-2015 10:53 AM
