installed aftermarket headunit with mach460 - volume is now very low..
I installed an Alpine IDA-X001 headunit with the Metra 70-5510 into my 2000 GT with the stock Mach460 amps/speakers.
The volume has decreased significantly compared to the OEM mach460 headunit. I suspect there is a voltage issue (the Alpine headunit uses 2v preouts).
Has anyone had this issue? Anything I should look at fixing? I wired everything correctly, however I did ground the headunit through the harness and not directly to any metal besides it.
I know there is a special wire connection you need to get for the Mach radios... I had to have one for my 98. Not sure if the same thing is needed.. I got it with my head unit from Crutchfield.
http://www.crutchfield.com/p_1207055...s.html?tp=2977
that is for 1989-2000 so not sure if that helps or not
I had to install a Scoshe OEA-4a to get my aftermarket radio to work with the Mach 460
http://www.amazon.com/Scosche-Oea4-4...=scosche+oea-4
there is a loudness setting on some head units. low med and high. I keep my pioneer on MED and the vol at 21 is about as loud as you can stand. with it set on Low youd have to crank it to 40 - 50. This new head unit you have may not have that setting called "loundess" is your unit loud when cranked up ALLL the way? it will be low by defaulty i assume
