Last edit by: IB Advertising
Browse all: Ford Mustang GT Powertrain Guides
- Ford Mustang GT 2005-2014: How to Replace Radiator
Step by step instructions for do-it-yourself repairs.
Radiator fan motor replacement - need help
Yep, def sounds like the connection melted (as they tend to do). It will keep killing fans and fuses until you fix it. I just cut the end off mine and did 3 female ends to connect to the fan.
Mine didn't look bad the first time, then when I checked after the second fan motor, it looked like this:
Yes and No, though I will present scenarios in No/Yes order:
A moderately "burned/melted" connector would behave as a "highish" value resistance in series with the fan motor, limiting the amount of current it could draw and reducing its speed and power--basically the same thing the ballast resistor does to achieve the low fan speed.
engine cooling fan low speed ballast resistor (the smaller component below the wire-wound resistor is a thermal fuse):
That's the "no" part.
The "yes" part is that if the connector were badly burned up, and sufficiently resistive, the fan motor might no longer turn fast enough to cool itself. When that happens it would overheat, burn up the grease in its bearings and seize.
The thing about dirty corroded overly resistive connectors is that they themselves heat up and get worse--which makes them heat up, and get worse--which makes them heat up, and get worse; etc...
DrunknRuckus
08-23-2015 10:05 AM
