4.6L mustang oil leak
I was logged out somehow when i clicked submit the first time, and lost everything i typed, so this is my second go!
I own a 1996 lincoln MKVIII with the 4.6L DOHC 32v
It has an oil leak at the oil filter adapter housing
Here are the pictures:
https://www.facebook.com/media/set/?...3&l=855c93348a
At first i thought it was a power steering leak because sometimes when i start it up the power steering whines real ****in loud for a few minutes until it warms up, but this is what i assume is the hoses deteriorating internally and clogging the power steering pump up.
As you can see in one of the pictures, the power steering reservoir has remained very full, however it has gone from a clean ATF color to a nasty burnt smelly brown color, so i dont think my power steering system has much time left.
It leaks about a quart of oil a month, so i know this must be oil blowing all over the bottom of the car.
The sensor on the oil filter adapter and the plug on the bottom of the oil filter adapter both have bright orange tape on them so i assume i am not the first person to tackle this leak.
Has anyone had a leak in the same spot, is this a common occurance in these engines, is my diagnosis correct, etc
thanks in advance for any and all advice and support!
mustang power!!!!
mustang power!!!!
the orange is factory sealant, seen several that way. it looks to be the gasket between the block an the adapter or a cracked adapter. either way, remove the adapter, check for cracks. if none, install with new gasket.
91StangOwner
Aug 20, 2015 11:34 PM
Aug 11, 2015 03:43 PM
