Crankshaft keyway broken
Hi all.
I have a 2002 Mustang Gt. I was recently driving when I lost power steering. I pulled over and popped the hood to see mu car was running but the belt was not moving. I turned off my AC and that seemed to fix the problem. Later that day I heard a wobbling sound. I popped the hood again and saw my harmonic balancer was wobbling on the end of my crankshaft. I shut the car off and tightened the bolt. It was fine for a couple days. Then i was driving and lost power steering again, as I was pulling over I lost the bolt out of the end of my crankshaft and the harmonic balancer fell off the front on the crank. The key snapped off balancer and was left in the crank. I bought a new harmonic balancer and key but when i put it on i got the same wobble as when the old one was on it.
My question is do I really have to put a new crankshaft in the motor if just then end of if is somehow messed up?
If there any other way to fix this issue?
Thanks for any help or ideas
2002 Mustang GT
2002 Mustang GT
Are u tightening to bolt to the proper spec? Are the threads for the bolt in the crankshaft stripped out? It shouldn't back out unless its under tightened. The stock bolt is also torque to yield, once its tigtened down it is NOT reusable, make sure u get a new bolt, this can really jack up your motor if that bolt comes out because when its tightened down it puts the crank trigger in the right spot behind the timing cover.
I'm confused, they key came off the harmonic balancer? As in the balancer split at the rubber? Or the keyway came out of the crankshaft? The key (the raised portion on the end of the crank) is removeable. The keyway on the balancer is just a slot that is machined into the balancer.
If that bolt has been torn out of there a few times now you may have ruined the threads inside the crank, which is repairable but probably won't be fun.
Technically speaking,The bolt Doesnt hold the balancer on. the balancer is a "Press-Fit" onto the crank "Snout". the bolt is there to ensure it doesnt shake free.
Now, If the key is broken, it means that the balancer "Spun". ANY Imperfection to the crank that interferes with The "Press Fit" of the balancer makes the crankshaft unuseable.
Yes sorry, The keyway is not broken. The harmonic balancer spun on the end of the crank shaft before falling off. I have a new one with key. The first time I re-tightened it it was to to the torque specs set by ford (70 to 90ftlbs). With the car in gear and E brake on. Basically the end of the crank shaft is F'd is there anyway to fix just the end of the crank shaft? I know I can use a die kit to re-thread the inside but its the outside that seems to be messed up. Id really like to not tear down the motor to replace it.
2002 Mustang GT
18" SVE Drift wheels
Koni Suspension
Trick Flow Throttle body w/ roush spacer
BBK intake, bassani X-pipe, flowmaster dual
2002 Mustang GT
Koni Suspension
09-25-2015 06:58 PM
Calizic
08-28-2015 01:46 PM
