2001 GT Coil Pack Problem?
As you can see im new here. I need some help diagnosing a problem. My car will hesitate/stutter when accelerating up hill or getting on the gas. It only does this when its warmed up though. Been told it may be a coil pack going bad. Any advice would be great.
Thanks
Thanks
Before you jump to any conclusions and start replacing the coils (also assuming no codes present), check the condition of your spark plugs. If it's been a while or never then just replace them. While you have it all apart, inspect the coil boots for any damage, deterioration or signs of arcing (will likely appear as a brown-ish dusty substance); replace boots as necessary. If you end up doing the plugs, torque spec is 11-14 lb/ft, be careful not to exceed that.
musnicki
09-23-2015 07:11 AM
mungodrums
Suspension
09-07-2015 07:22 PM
