Throw out bearing?
Old 05-25-2014, 06:34 AM
Evan02
Evan02's Avatar
Default Throw out bearing?
There's a constant noise coming from my clutch kind of like a squeaky belt. As soon as I press the clutch it goes away. Is this the bearing or something else?
Evan02 is offline
Old 05-25-2014, 07:17 AM
Timspony
SVT Section Moderator
Timspony's Avatar
...Sure sounds like a TOB ~ just monitor the noise for now
Timspony is offline
Old 05-25-2014, 05:52 PM
Evan02
Evan02's Avatar
Ill try to post a sound clip later
Evan02 is offline
Old 05-25-2014, 10:16 PM
VTX1800N1
VTX1800N1's Avatar
I had a similar issue on my 88 GT years ago. Replaced the throw out bearing and it was quiet for a week. The problem returned. It turned out to be the transmission input shaft (which is what the throw out bearing rides on). I replaced that and the problem was gone for good.
VTX1800N1 is offline
Old 05-26-2014, 05:20 AM
Evan02
Evan02's Avatar
Thanks. I went an ordered a clutch kit from AM. If it's still there I'll know what to try next.
Evan02 is offline
Old 05-26-2014, 06:36 AM
VTX1800N1
VTX1800N1's Avatar
I should say, it wasn't the actual shaft, but the metal housing that bolts to the front of the transmission that goes around the input shaft and the throw out bearing slides on it when you use the clutch. This was on the old Borg Warner 5 speed. The OEM was aluminum and didn't wear well. The replacement I got was steel, much better. It's also called an input bearing retainer.
Sent from my XT1080 using IB AutoGroup
mrtrodonet
09-19-2020 03:12 PM
6bangr
02-15-2016 07:40 AM
KingRando
10-02-2015 08:06 AM
Drastang
09-30-2015 03:48 AM
Offendant
09-23-2015 07:21 PM
Quick Reply: Throw out bearing?
