pretty simple, pop the radio bezel off, there will be a few 7mm black screws holding that and the hvac unit in, and on the back will be 3 tiny bulbs you twist to get out. replace bulb. I forget the appropriate part # but any parts store should have them
They use #194. You'll want to unclip the electrical harness behind the fan control switch so you can pull the panel out far enough to access the lamps.
Thanks for that info, are these bulbs also the same ones that are used in the gauge cluster?
