How low should i lower?
Old Oct 21, 2005 | 12:28 PM
98GTstang's Avatar
98GTstang
Default How low should i lower?
Im having a hard time trying to find lowering springs..i dont know how low i want my mustang..if anyone could tell me whta they have and show me some pictures that would be great thanks!
Old Oct 21, 2005 | 12:55 PM
red2k1gt's Avatar
red2k1gt
Default RE: How low should i lower?
most people go with the 1.5 inch lowering kits from either eibach, bbk or any other name brand springs.
Old Oct 21, 2005 | 04:18 PM
monkeydude3's Avatar
monkeydude3
ok I am not sure what brand kit the guy who owned this before me put on it but he lowered it 2" in the front and 1 7/8" in the rear... honestly I would have only done a 1" because it seems a tad to low for me, but eh whatever it handles great
George
1997 GT 5 speed
[IMG]local://upfiles/22622/4CA40C9F63D34D6F83CC7C29D6C041D3.jpg[/IMG]
Old Oct 21, 2005 | 04:56 PM
NewMexMustang's Avatar
NewMexMustang
Just don't go too low, then you'll have to sideways over EVERYTHING! I once saw a ricer eclipse have to sideway across an intersection, so I tailed his *** across it.
Old Oct 21, 2005 | 09:53 PM
04BlueGT's Avatar
04BlueGT
1.5 inches. H&R makes 2 inch drop, FRPP, Steeda, DZSport, Eibach, to name a few. Different drops depending. I have the DZSports poly isolators, so my drop was significantly less. About 1 in the rear and maybe 1/2 up front. I hoping it will settle more over time.
Don't forget, you will need an alignment at a minimum. I would recommend C&C plates, bumpsteer kit, or aluminum offset rack bushings to correct steering geometry. Many companies make these parts, including FRPP and Steeda.
Best of luck to you.
Old Oct 21, 2005 | 10:04 PM
Dark_Horse's Avatar
Dark_Horse
Get a 1.5 drop its not too low and it looks alot better, but if you want a drag suspension go for 4cyl fox springs up front and Fox 8cyl springs out back, i think that will lower it also
Old Oct 22, 2005 | 01:22 AM
jishead's Avatar
jishead
Eibach Sportlines is my fav. The Pro-kit lowers less and it's like why bother unless you live on crappy roads or something. I have not had any probs with the Sportlines in the St. Louis, Illinois corn fields, nor northwest arkansas areas. Have to use common sense when you are in a GT anyway. My friend drives a C5 vette and his is so much lower OEM than my Sportlines. He scrapes over mouse droppings!
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
TCStangerv6
Oct 11, 2015 05:57 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
