Back in market for cams on 2.1 KB
I know their is some articles from back when or whatever, I know Modular Powerhouse used to be the standard, however they are no longer. Just want to hear what is the best cam for the 2.1 KB setup. I have an MMR 600 with stock heads, currently at 10 psi, plan on going up to 13-14 psi with the help of a water meth kit. Thanks in advance for any help
Contact MMR, Cushman, Hitech, etc for their blower cams. Personally, I have seen great results from Comp's 268's and 270's.
In all reality, only having a mmr 600 block, just turn up the boost. Adding cams will be a costly endeavor with little gain vs adding pulleys and reaching the internals limits. What compression ratio are you running?
