TPS sensor low circuit
Old Oct 27, 2005 | 11:25 AM
boostedgt02's Avatar
boostedgt02
Default TPS sensor low circuit
Even though I have not fixed this yet would it be ok to drive like this until I have time to fix it?
Old Oct 27, 2005 | 03:07 PM
ShadowDrake's Avatar
ShadowDrake
Default RE: TPS sensor low circuit
Throttle Position Sensor... You should probably get that fixed... Your A/F ratio is going to be off unless at WOT (which won't read properly because your TPS is messed up )
Old Oct 27, 2005 | 03:14 PM
boostedgt02
Now if I installed a bbk tb with out the black ring it comes with and installed the tps sensor would this cause the sensor to go bad at all?
Old Oct 27, 2005 | 04:25 PM
boostedgt02
If I clean the IAC with tb cleaner would that help at all?
Old Oct 27, 2005 | 04:27 PM
boostedgt02
Also with the tps sensor I did not have the little black piece that came with the bbk tb on at the time. Would the tps sensore get messed up at all?
Old Oct 27, 2005 | 04:40 PM
Tim37's Avatar
Tim37
the only thing to do to make ti better is a ride to the parts store.
if bbk said use a littel black part then it is suposed to be there.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
