2004 Mustang GT Fuel Pump
Will not crank, sounds like the fuel pump isn't kicking on. 125k miles; checked the relay in the trunk and it was depressed (not kicked out). Anything else to check or other way to confirm fuel pump is the issue? Thanks
Check for voltage at the inertia switch in the trunk, it's pretty much the last "stop" before the pump. If you have power to the IFS switch then strong possibility of failed pump. If not, then it's an electrical issue that lies elsewhere.
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
Jarrod@latemodel
LatemodelRestoration.com
02-22-2013 08:38 AM
Inspiribomb
10-17-2006 12:24 AM
