New intake problems
Old Sep 12, 2020 | 07:10 PM
Mostprofessionalguy's Avatar
Mostprofessionalguy
Default New intake problems
I know this has been discussed but none ive found that match my problems, 03 mustang gt, old lower intake coolant nozzle broke off in hose and sprayed collant everywhere, i replaced this. Now it has a rougg idle and a poping almost kncoking noise from the engine heard through the exauhst maybe its getting too much air or i habe a misfire please help
Old Sep 13, 2020 | 06:21 AM
Benni614's Avatar
Benni614
Do u have a cel light
whats the code
Start there before thinking to deeply
Old Sep 14, 2020 | 10:42 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
did you get a bunch of coolant down the intake ports when you removed the old manifold? did you clean the coolant out from the spark plug tubes as well? you can hydrolock and damage your motor if you arent careful with the coolant clean up before attempting to restart engine. or your ignition coils are messed up from getting coolant on them,
Old Sep 14, 2020 | 03:01 PM
Mostprofessionalguy
whats the code
i havent checked codes cause there was no engine light thrown a few of my fuel injector caps wer cracked and im replacing all the o rings but ill check for codes thankyou
Old Sep 14, 2020 | 03:03 PM
Mostprofessionalguy
dont think its possible i literally sprayed most if not all my coolant out when the intake broke and there i was carfull in that way ive done intakes before just this time is different
PowerPonyPatrol
Jan 13, 2008 04:41 PM
speedsk8er
Oct 4, 2007 11:13 PM
88scgt
Apr 5, 2006 04:47 AM
Rauchle05
Jun 23, 2005 08:38 PM
Pitviper100
Mar 12, 2004 03:19 PM
