Stalled on hard braking. Threw me a p1233. Need help.
Stalled when locking up brakes in the rain because I did not clutch in. Got it home and checked the codes and it gave me the p1233 and another about fuel rail pressure. Made sure inertia switch was pushed in and I'm 90%sure it is. Reset codes and it was fine for a drive then went for another drive later and it threw a p1000 and a p1233. I don't think inertia switch was triggered and the car does run and drive. It did idle rough and felt a bit off. Gas tank read half a tank lower than it should for a second then switched on and off and fixed itself. The gauges and radio also turned on and off quite a few times. I'm not sure why this is happening and looking around I have seen no clear answers.
