what mod is next?
RE: what mod is next?
ORIGINAL: 2000gtmustang
got 4.10s about to go in my car....what should next 3 mod be and in order of them please.....already have slowmasters on it...plan on going with LTs and x pipe and full bassani...but wantthat to come in spring....
ORIGINAL: Dan04COBRA
Also, if you are on a tight budget, forget the UDP's as they will have to come off with a supercharger.
Joey makes an excellent point also. Everyone wants the go fast NOW!!!!! Its really not logical. It makes much more sense to set ur car up with springs, shocks, subframe connectors, control arms, tires before you start bolting on all this power. Just get that FULL exhaust on(LT,midpipe, catback), and start working on the boring things. You can make your almost stock car run quicker times at the track than a car with more HP. Your suspension and tire setup can be the difference between 14.9 and 13.9.
GET THAT SHIFTER CHANGED OUT FOR A S/T!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Besides gears, I reccomend s/t shifter more than any other mod!
ORIGINAL: ZW99GT
Ok, so I will not ever reccomend them again, becuase i have only "heard" they were good from my dyno tuner, but Code will you explain please? So i can tell people why not.
ORIGINAL: code3GT
Stay away from Patriot.
ORIGINAL: ZW99GT
wait a minute. So you are asking what is after gears, and full exhaust? Well, how much $ do you have to spend. There are alot of ways to go. Most common things are U/d pullies, CIA and TB/Plenum. It really doesnt matter which order. Some people wait for the TB/Plenum, but i say if its going on eventually, who cares.
If you got the dough, you could make a badass N/A car with Ported/PAtriot heads, and a stage 2 cam.
If you really got the dough, See about a supercharger kit.
Let me know what you want to spend and we can tell you what to do.
