Cometic Heads gaskets
Old Dec 2, 2005 | 06:43 PM
yoteehunter's Avatar
yoteehunter
Default Cometic Heads gaskets
I have read that the use of cometic head gaskets will bring compression down to normal 9.4-1 if used in a .084 thinkness. Factory compressed thikness is .039. Now my question is that if you used thicker head gaskets, how would this effect the timing chain, and front cover ect? Are they realy usable or is someone just talking out there fog pipe?
Old Dec 5, 2005 | 12:12 PM
yoteehunter
Default RE: Cometic Heads gaskets
Anyone?
Old Dec 5, 2005 | 02:22 PM
Tim37's Avatar
Tim37
the timing chain tentioner should take care of the slack in it and there shouldn't be enougth diffence to make the fornt cover have any problems but if they do you could use a file and work the bolt holes just a littel and get every thing to line up right.
Old Dec 5, 2005 | 04:08 PM
yoteehunter
Thanks this is a real major stepping stone for pi swapers. Now a supercharger could be used on a early non pi motor with pi heads, and cometic gaskets will withstand the pressure they are the next best thing to oringing the heads. Realy all they are is stainless steal plate stacked between gasket material to whatever thickness you need. anyways cool! Just another option for use non pi ers.
Old Dec 5, 2005 | 06:44 PM
Tim37's Avatar
Tim37
now when you do a pi head on a non pi motor the compesion ends up about 10:1 so you would really need ot get new pistons to do any kind of boost.
Old Dec 5, 2005 | 11:59 PM
Dark_Horse's Avatar
Dark_Horse
^^ acutally its 10.5:1
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
