? on ebay subframe connectors.
RE: ? on ebay subframe connectors.
ORIGINAL: wwmost
what exactly do subframe connectors do?
They should. Just make sure its a boxed type tubing not a circular type. The boxed tubing is stronger... Ooh you might also want to get some with a painted finish to resist rust, or paint them after you install them to avoid corrosion.
ORIGINAL: JonBeast
I'm going to order some ebay subframes too....can't go wrong, just tubes of metal.
And for $50....I'm willing to take the risk.
im going with the Kenny Brown ones just cuz i know they are a trusted name and plus i saw some for only like 90 bux though most others don't cost much more though i did see some hardcore Steeda ones that were up there in price. they should work i mean they are designed to do what other sub frames will do just either the material is not as durable and will rust or not be as tight or it could be a name thing as it is with everything.
ORIGINAL: DILO2001GT
09-16-2015 07:53 PM
yourmom6990
09-14-2015 10:52 PM
09-01-2015 08:16 PM
