strange noise...
strange noise...
hey guys, have a strange noise. it's high pitched. it goes with the engine rpm. don't hear it when idling. (it's an auto by the way) when i take off i start to hear it from 1500 - 2000 rpm. trans shifts ok. i thought maybe the water pump was going out. don't think that's it. then i thought the idler pulley, but i popped the hood & didn't really hear it in front of the engine. it's coming from underneath, back of the engine towards the tranny. like i said, it shifts ok. any ideas? it's driving me nuts cause i can't pinpoint the noise. thanks for the help.
RE: strange noise...
What have you got done to the car? Is anything rubbing, is it in all gears at those rpms, or just you're lower 2? Maybe something is rubbing/grinding on the driveshaft... look around for metal scoring, just an idea to start at :-p
well i know my car idler pulley is bad and it has the same symptoms as yours. I can hear at around 2000 rpms but not while it is idling. I know this because my car likes to go through them like nothing before.
I had the same problem. It sounded like ball bearings grinding. I thought it was the alternator so i replaced it only to start it up and still hear the noise. Then i took it to ford and they couldn't find the prob. after an hour of looking so they didn't charge me. I was just about to change my water pump out when my uncle found out the noise was coming from the tensioner. I haven't replaced it yet though cause i am waiting for parts. If that isn't it i guess i will be replacing the water pump. Might as well go with an electric one.
thanks for the help guys. something i didn't think of, forgot about actually, the original serpintine is on it. it's very dried out. it's not split, but that's what i think it is now. if not that then the idler pulley. fixing what's wrong on a car is usually the easy part(usually), figuring out what's wrong is the hard part.
hey rustyshackle4rd, your pizza is ready.
ORIGINAL: white 98 gt
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MustangVixenGT
09-16-2015 04:16 PM
