speedometer calibration
Old Dec 13, 2005 | 05:13 PM
Coley2002GT's Avatar
Coley2002GT
Default speedometer calibration
I'm planning to install 4.10 gears this spring and I was wondering if there was a way to recal. my speedo other than buying a handheld tuner. Can a Ford dealer or a garage with a standard DRB do it for me???
Old Dec 13, 2005 | 05:33 PM
Matts00GT's Avatar
Matts00GT
Default RE: speedometer calibration
You can buy a speedcal for a hundred bucks. Really not worth it unless you can find it used.
Old Dec 13, 2005 | 06:10 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
i myself bought a dallasmustang speedcal
90 bucks where i found it at ninosport, not sure what it is now though
but not only does it correct for gear changes, im doing a 15" tire conversion this summer, and the speedcal can correct for rear tire height changes. so its kind of like a two for one deal
i also believe they make the little speedo teeth gear things for like 15$ check into one of those
you should be able to find them all over the place
Old Dec 13, 2005 | 06:13 PM
Matts00GT's Avatar
Matts00GT
I believe the gear is only for the 98 and earlier years b/c they weren't digital. 99-04 doesnt use the gears...I think.
Old Dec 13, 2005 | 09:53 PM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: Matts00GT
Your right!
Old Dec 13, 2005 | 10:42 PM
2000STANGGT's Avatar
2000STANGGT
Speed cal $95.00 to $100.00
Old Dec 13, 2005 | 10:53 PM
sprostang's Avatar
sprostang
I ♥ Acer
I would just hold off and get a tuner. You wont be dissapointed about it in the long run. Especially if your gonna do more mods. The speed cal is about $100 as said, a shop will probly charge you $100 (at least) to install it. Therefore your half way there for the cost of the tuner. Get the tuner and dont look back. Youll be better off.
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
Musthang
Mar 3, 2004 10:05 PM
skatepony
Jul 23, 2003 12:34 PM
