Changing Brake pads 99 cobra
I can't figure out how to ****in change these things...I see three screws, one I unded and oil started comming out so I screwed it back up then the one below it after I finally manged to get it loose and remove it, it didn't seem to do anything...wtf...how complicated can this **** be? can you guys give me some advice, I have to do but but for now i'm workin on the front
RE: Changing Brake pads 99 cobra
Well if you loosened a screw and you got oil out of it, you have loosened the bleeder valve. It would be wise to bleed that side before you go out for a drive in that car. You may have intorduced air into the system.
There are two large bolts that hold the caliper on. Once loosened and removed, the caliper can be removed and the pads replaced. Both are on the back side of the caliper (facing the motor) one on top and one on bottom. Do not loosen the ones for the guide assembly.
okay...all I see are three bolts and one of them (the middle one) is where the oil came from, but I did loosen the lower one and removed it and the clipers didn't seem to budge...?
Go to autozone and buy the haynes/chilton, or look online for a step by step guide for the brakes... If you cant find one send me a PM and ill try to scan the pages for it
Diode Dynamics
28
05-26-2022 12:02 PM
