Spring Isolators?
Old Dec 29, 2005 | 11:02 PM
89Convert's Avatar
89Convert
Default Spring Isolators?
just wanted to know from you guys with springs if you installed isolators? what are the advantages? disadvantages?
Old Dec 30, 2005 | 12:14 AM
Voodoo's Avatar
Voodoo
Default RE: Spring Isolators?
I did not install the isolators, I just used the old ones. I wanted the car to lower as much as possible and I read somewhere that the polyurethane ones will keep the car 1/4" higher. My front ones were a little wore though.
Old Dec 30, 2005 | 12:50 AM
89Convert's Avatar
89Convert
do you get any noise from your suspension?
Old Dec 30, 2005 | 01:40 AM
Aixtreme89's Avatar
Aixtreme89
I reinstalled the stock spring isolators on my eibach springs. Its not worth, the extra 1/4" without them. I could only imagine how much noise your front and rear suspension would make over bumps. Metal and metal, isnt going to make your ride quiet.
Old Dec 30, 2005 | 01:41 AM
4ZZS's Avatar
4ZZS
I installed a ProKit a few months ago. I am happy with the distance they lowered the car (1 1/4 - 1 1/2") on my convertible. I reused the original rubber isolators and I believe we got everything securely back in place. I "think" that I hear some minor clunking sounds coming from the suspension that may not have been there before, but I'm sure I am paying more attention to it and "trying" to hear sounds. I am taking the car into a tire center for rotation in a few days and will ask them to check everything on the suspension to see if they "see" the noise makers.
I had also heard that NEW poly isolators wouldn't allow new springs to drop as much as I wanted, especially since the drop on convertibles isn't as much as coupes to begin with. So that is why I just reused the originals. I don't think you would want to go without any.
Good luck.
Old Dec 30, 2005 | 04:19 AM
sandcracker21's Avatar
sandcracker21
ORIGINAL: Voodoo
+1
just use the stock ones.....unless they look beat to ****
Old Dec 30, 2005 | 10:14 AM
Voodoo's Avatar
Voodoo
ORIGINAL: 89Convert
I reused the stock rubber isolaters. No noise.
Old Dec 30, 2005 | 12:17 PM
04BlueGT's Avatar
04BlueGT
I replaced my stock units with prothane polyurethane ones. I lost about 1/4 inch of drop, maybe more. Other than that, the prothane parts have not caused any problems.
Old Dec 30, 2005 | 12:45 PM
Voodoo's Avatar
Voodoo
ORIGINAL: 04BlueGT
How thick are those. The stock ones are about 1/8-3/16. That would mean the poly ones are 3/8 +" thick. Hmmm
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
