squeakin breaks
Old Dec 31, 2005 | 06:48 AM
bobjenkins's Avatar
bobjenkins
Default squeakin breaks
the brakes were squeaking pretty bad at times so I sanded the rotors down with rough sandpaper and it helped alot is this problem going to come back? Ive got alot of brake pads left I just dont want it to start squeaking again when I get new brakes in a while
Old Dec 31, 2005 | 07:26 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: squeakin breaks
Sanded the rotors?!
Hah, you should get new rotors and a set of cheapy brake pads if you plan on doing an upgrade in the future. I doubt those rotors are any good now after you took sand paper to'em.
Old Dec 31, 2005 | 07:54 AM
bobjenkins's Avatar
bobjenkins
my grand dad owned a car lot he did this for years on rotors that squeaked no problem
Old Dec 31, 2005 | 08:02 AM
Dan04COBRA's Avatar
Dan04COBRA
You didn't specify exactly how you sanded them LOL
You can lightly sand the surface, which will eliminate some squeeling. You had me laughing, thinking you took some 60 or 80 grit and really carved those babies up.
Old Dec 31, 2005 | 11:56 AM
nathansmith50's Avatar
nathansmith50
ORIGINAL: bobjenkins
of course no problem......because he sold the cars. what else did your dad do? saw dust in the transmission to keep it from making noise?
Old Dec 31, 2005 | 12:31 PM
Tim37's Avatar
Tim37
your problem is probably cheap break pads either that or you have a set of pads ment for the track. i am leaning tward cheapies. i don't think you hurt you rotors but heres what i would do. have the rotors turned and buy a set of wagner thermo quiet pads. garanted no to squeel if they do they will replace for free. life time garanteed if they wear out you get a free set. and they reduce break dust but no garrantes.
Old Dec 31, 2005 | 12:56 PM
Voodoo's Avatar
Voodoo
I've took some light sand paper to my rotors many times while changing the brakes just to take the glaze off. It won't hurt at all and should actually help, your Grandpa is no newbie to cars and he knows what he's talking about. Usually when you buy new brake pads they give you some sealer type compound to put behind the pad to keep it from squeeking. I'm not sure if they sell it separetely but some silicone should work about the same. They may sell the stuff at an autoparts store though. Try that, it may work.
Old Dec 31, 2005 | 04:45 PM
kartracer55's Avatar
kartracer55
voodoo.. CRC sells the stuff in a bottle, its enough for like a million brake jobs though. I know it autozone they sell tiny like 1 job packets of different sealers and such for lieka 1-2$ a piece. Worth checking out. Are the pads just worn?????? Alot of(if not all) pads have wear indidcators that squeak, and its amazing how many people dont even bother to look.
Jim
Old Dec 31, 2005 | 06:07 PM
bobjenkins's Avatar
bobjenkins
yeah he was talking about taking the glaze off so it didnt squeak
Old Dec 31, 2005 | 06:38 PM
Voodoo's Avatar
Voodoo
I'm sure it would go away if you put on some good pads and cut the rotors. The reason it's sqeaking is because both the pads and rotors are probobly all glazed. Those pads are probobly hard as hell. I want to get some HP pads myself cuz my brakes suck. The better pads may create more dust and wear faster but will stop the car better.
jwog666
Dec 27, 2021 08:09 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
ccdguy
Sep 19, 2015 05:20 PM
Blk Vert
Sep 9, 2015 12:16 PM
