Think i blew my motor need help!!!!!!
RE: Think i blew my motor need help!!!!!!
ORIGINAL: mcget29
i just tried to oil cap thing and i didnt feel any air pulsing out
Well, there's a good chance the bottom end is fine. Next, do a compression and laek down test.
ORIGINAL: mcget29
how would i do that
how would i do that
2v98gt did u HAVE TO do a rebuild or was it your decission. If i did have to rebuild the motor how much would it cost?!?!
BTW, i dont feel a power loss or anything while driving it, ( i only drove it about 2 miles home from autozone ) and 98gt how did u spin ur bearing??
If you didn't feel any power loss, then you certainly didn't break a rod. And of course you've already put your hand on the oil filler and didn't feel any air...So you've ALMOST eliminated a bottom end problem.
Pretty much the next thing you need to do is have a compression and leak down test done. Theres very little else you can tell unless you just start tearing it down and having a look, but it sounds like you're not well versed in how an OHC motor works, so I'd just take it to a shop and see what they tell you. Might want to take it to two different shops and see if they come up with the same answer.
Good luck.
Good luck.
I have another question about the oil cap test, will the air be coming out hard and should i give it some throttle when i put my hand over it, because its definatly not putin any air out hard enough to feel.
ORIGINAL: mcget29
I tried the oil cap test again and i can feel a lil air comin out but barely any...
Oh, you will know. When I broke the rods on my motor, the air was coming out of there so hard it would push my hand away.
logan409
09-26-2015 07:43 PM
