IS THIS fuel injector info article right???
I just cant figure out if i should jump to 30lb injectors with my nitrous or not, i switched to 24 and things seem better, but according to this article 24lb is for about 300hp, and one guy told me he runs 150 dry shot of nitrous on his 19lbs, maybe i should leave well enough alone... I have not had a shut down issue with the new injectors like I did with the 19lb, but i wonder and was thinking of 125 shot, if anyone had experience with the venom kit you know they are more on the side of saftey
http://www.superstallions.com/tech/e.../injector.html
RE: IS THIS fuel injector info article right???
ORIGINAL: ericdiver
Well its just in most my research it seems like 30lbs injectors at 90% cycle are good for about 375hp, and with the nitrous and little mods i have done I am about there, am i missing something???? and thats with 30lb injectors, my question would be is nitrous the same as a supercharger?? In terms of fuel demands.... or because nitrous is taking up a little space and cooling the fuel do u not need as much fuel as you would when u compress it with a supercharger?? All supercharger kits come with 30lb injectors and fuel pumps( which is why i choose 24lb no point if my pump cant provide pressure ) and the supercharger kits are pushing the same horsepower as my car? I think i am thinking about this too much.....
ORIGINAL: ericdiver
im runnin 42 lb injectors in my car and they work fine. 310lph fuel pump too.
I'm not sure when Ford started it, but the '04 and, I think, the '03s have 21# injectors. They are the ford-bosch units and are very much pink.
Good Lord, why did it have to be pink? Was violet already taken?
