dynoed the gt tonight!!!
Old Jan 22, 2006 | 02:23 AM
  #21
ShadowDrake's Avatar
ShadowDrake
Default RE: dynoed the gt tonight!!!
ORIGINAL: HaV
ORIGINAL: sandcracker21
757GT is right, you will dyno a TINY less with aftermarket gears
Yep. When you switch gears the load on your transmission is no longer 1:1 in 4th, its just a little off. I went over that with the guy who dynoed my car.
Not true, 4th gear is still 1:1 for ratio at the transmission, your rear ratio was 3.23(? not sure exactly, you know what I mean) before the swap, and it is 4.10 after. The driveshaft spins at the same speed per RPM and gear before and after the gear swap, just the wheels will spin at a different speed.
Old Jan 22, 2006 | 04:19 AM
  #22
rbstang's Avatar
rbstang
ORIGINAL: thirteensecondgt
well i put my car on the dyno tonight and i put down 238 to the wheels....with very few mods.....4.10 gears, diablo programmer, c&l plenum 75mm-no aftermarket throttle body kit, and i got flowmaster and gutted cats....
pretty good numbers
Old Jan 22, 2006 | 01:18 PM
  #23
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
your cars a stick right?
Old Jan 22, 2006 | 02:25 PM
  #24
210stang's Avatar
210stang
shouldnt you be making better numbers?
maybe those gutted cats are robbing power
you should get a mid pipe to replace those gutted cats
Old Jan 23, 2006 | 02:37 AM
  #25
HaV's Avatar
HaV
ORIGINAL: ShadowDrake
ORIGINAL: HaV
Everything that I have been told is that when you change your final drive you slightly alter the intended load on your entire drive train at a specific rpm.. its not a huge load change, but it makes it no longer a perfect 1:1.
Hehe, wouldnt be the first time I wasnt right though. I'm not a newb, but definatly not nearly as experienced as a lot of the guys on this board.. definatly correct me if I am wrong though [&:]
Galactic
Apr 29, 2019 02:56 PM
articman
Jun 21, 2018 11:45 PM
BeatnikFink
Oct 1, 2015 08:00 PM
heslekrants
Sep 23, 2015 04:02 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
