Check Engine after spark plug install!?
Old Jan 23, 2006 | 12:33 AM
SilverGTV8's Avatar
SilverGTV8
Default RE: Check Engine after spark plug install!?
Really I can do a plug change in under an hour. You just need to have the right combination of extensions to get by the fuel rail and sensor.
Old Jan 23, 2006 | 01:02 AM
DrUnkEnMaStEr69's Avatar
DrUnkEnMaStEr69
i just mean that in comparison the right side is way easier than the left
Old Jan 23, 2006 | 02:11 AM
monkeydude3's Avatar
monkeydude3
I did my 97 GT in about one hour exactly (8 plugs). I walked into autozone and bought the OEM stock meant for the car motorcraft plugs. They are double platinum or something. Unless you are doing crazy mods, stock OEM plugs are all that you will need.
Generally when I do tuneup related stuff, I put in what it came from the factory with.
As far as I know bosch is a GM oriented plug?? You will want motorcraft or autolite (same exact plug different names) in your Mustang.
Peace
George
Old Jan 23, 2006 | 02:12 AM
HaV's Avatar
HaV
ORIGINAL: DrUnkEnMaStEr69
That aint no lie... much less to pull off on the right side to get to them.
Just checking.. you did pull your battery for a few min then put it back on just to clear it right? Anytime I get a code right after swaping something I try that. It never hurts.
Old Jan 23, 2006 | 10:45 AM
DrUnkEnMaStEr69
yea i tried resetting it but it just came up again. So today i'm gonna go get the code pulled somewhere, and ill have to go buy soem new plugs aswell [:@]
Old Jan 23, 2006 | 10:49 AM
blackbetty01's Avatar
blackbetty01
mine cam on after installing new plugs because I didn't plug one of the fuel injectors in securely. I would start with checking every connection again and if one of them wiggles into place I would pull the battery again.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
overnight89
Aug 22, 2015 09:02 PM
microgt
Aug 20, 2015 07:12 AM
