PCV solution for oil draw thru...
Jaz Mini Breather (1 Pint) for $55
this is the solution i ended up going with to stop the draw thru from the pcv system. gotta mount it a hook it up but it shouldn't be hard at all.
http://www.jegs.com/webapp/wcs/store...0469&langId=-1
its a breather filter + oil catch can.
there are catch cans which can be used to reroute the pcv into the intake if you dont want to go the breather route.
i was going to tig weld in a baffle in the valve cover but canceled and got this instead. much cheaper and should work well.
RE: PCV solution for oil draw thru...
yeah you could buy any air/water seperator from lowes/HD for air compressors/ paintball guns etc for much cheaper. but those are still missing a breather and not made to withstand heat. ive read too that the seperators dont catch all the oil vapors and its possible a larger "catch" might help
and a breather, i didn't think, took care of the drau thru issues with oil as it would clog the breather. not so bad if your NA but its worse on blower cars. (im sure you know, you got both)
this Jaz breather will seperate the oil from the air and function as a breather as well, so there Should not be much oil on the breather over time.
i think its a neat product and no mustang people use it so i thought i would share it
