Help! kidna of a problem
So i was goin to park....and my E brake like pulls up but is real easy. (not locking) Then i do it a few times and it catches and locks up. so w/e then the same thing next time. And now it just dosnt lock at all. I havent had time to look at it. But the weird thing is how it liek worked then locked after a few trys. meaning the cable wasnt like broke. well ne ideas? other than the obv like cable might be broken. Juist wondering if it has even happend to u guys b4. The car also only has 14800 miles on it so its not like been used alot. thanx for the help
RE: Help! kidna of a problem
ebrake cable is seems to be loose or catching on something. look under the car and you will see a nut attached to a cable that runs to the rear brakes just tighten the nut up a little bit and see if that works. under driverside door or passenger side door cant remember which door its under.
if you can't figure it out I would hope with that milage it still has a warranty. Let them figure it out. I got a 97 GT and the parking brake has worked fine for me. Just check all the cables you can see to check if there are any loose or bad connections/spots.
George
George
i don't think you guys understand what he is saying, it sounds like the e-brake isn't staying in the up position which leads me to think theres a problem with the button mechanism on the e-brake itself
Nahh....i kno when i posted i didnt make it too clear. It does stay up, it just dosnt lock the brakes. It rachets up as normal, just very easy and stays up....just not locking the brake. Ill try what u guys sed and take a look. Thanx for the help
stangin1996gt
09-21-2015 11:01 AM
