Gear Help
Gear Help
I know there are probably a thousand posts about this, but I want to pick up some 3.73 gears for my 96' GT (5 speed). Is there any place that you guys would recommend? Also, I read the gear help post, and I need a speed-cal or tuner right?
Sorry for the re-post.
Thanks much,
Cody
Thanks much,
Cody
RE: Gear Help
An SN95 will need a speedcal or a speed sensor gears. If you have a 99+ you can change your speedo with tuner. You can pick up motive gears pretty cheap from most of the sponsors on this page, like Mustang Tuning. I like my FRPP's but they are a bit more expensive then the motives. Just make sure you get all your bearings replaced when you have them swap gears.
RE: Gear Help
ORIGINAL: HaV
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
