thinking cams.
RE: thinking cams.
ORIGINAL: n/a_threat
+1
Going to a stage 2 requires full exhaust and intake and MUST also forge the bottom end (internals: pistons, rods, crank, etc.) As mentioned before, if you do get a blower, you have to get special cams, same goes with a bottle set up. look here at vt:
http://www.vtengines.com/
ORIGINAL: code3GT
Stock internals??? Do a set of Stage 1's and call it a day.
+1
RE: thinking cams.
+1
ORIGINAL: code3GT
+1
RE: thinking cams.
ORIGINAL: gt96stang
It's not a must to forge the bottom end.. You would just not be able to use the full potential of those cams because you couldn't turn the motor that high.. Plus, n20 cams do not need special cams..
+1
ORIGINAL: code3GT
+1
RE: thinking cams.
ORIGINAL: MustangMafia
So you can use N20 with stage 1s with no problems?
ORIGINAL: gt96stang
+1
ORIGINAL: code3GT
+1
Military_man_88
12-02-2015 10:20 PM
