car does not run to strong, and not TPS voltage
the car runs and drives fine its just not that fast, i hooked it up to a ford scan tool and the TPS reads 0% all the time. any ideas? i tryed a spare TB and still it did not help. any ideas?
RE: car does not run to strong, and not TPS voltage
im not sure what the voltage is but the logger says 0% even when i move the throttle. is it normal for the car to drive fine? just not make alot of power?
check the voltage at the TPS, if its ok there (aka when you move the throttle it changes) start moving down the wire following it, and checking it till you see the volts go away.. thats the point you have the problem.
If its not outputting voltage at all see if any is going in. If not, same story follow it back till you see volts.
Could be a ECU problem as well unforutnatly. Have you checked all the connections etc etc?
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
