Dyno #s Procharged GT
I think he's correct in that the intercoolerdoes a good job cooling the chargethrough a stock intake manifold. But this TFS intake runs incredibly hot, because of its thick aluminum design. I would be really surprized if thereisn't any gain with this intake.
you're right on the money. I was at 360 and 355 torque on mine. The 3.85 that procharger puts on their P-1SC is a 3.85" rated at 8 psi. but mine was also only putting out 6 or so psi.
I'm down to a 3.20" now and putting out 11-12 psi. Going for 3.0" with 8 rib setup next year, But again , all in all, that's right one. 120 extra horses is always fun to play with. As far as 400, o/r x ipe isn't going to give you much more than MAYBE 6-8 hp. The methanol I'm not even familair with, but I know people using it, so I can't comment on that.
ORIGINAL: Quicktime_GT
I wouldn't worry to much about exhaust if looking for huge gains. A guy at speedy dyno only gained 12rwhp with a cobra after buying headers, mid pipe and cat back...
With more boost the numbers will change...
Another great factor is the style and brand of dyno you was on... dynojet? superflow? mustang?
On our 2v cars, headers make a huge difference. The junk stock style manifolds just arn't up to the task of a boosted setup.
Put it this way, the typical bone stock 2v should put down around 350 WHP at 8 PSI. With just a set of LTs/midpipe/catback you should be looking at 380+ WHP... pretty dammed good gains IMO.
It only gets more pronounced as you up the boost/power levels.
12hp is better than 0..That extra 12 will close the gap on 400.
ORIGINAL: tbirdscwd
I had my 2004 Mustang GT dynoed today and she put down 361rwhp and 353rwtq. Does this look about right. It is an Procharger P-1SC 8psi kit with a 2-core intercooler, but is only showing 5-6 psi output. I think that might have to do with my intake being far less restrictive than stock PI manifold. As far as the rest of the system goes: it has 42# injectors, 270lph aviator pump, SCT 90mm Maf, 75mm BBK Throttle body, and the new Trick Flow Track Heat manifold. I am still running stock exhaust manifolds, stock H-pipe, and Cat-back Borla.
Do a header and mid pipe swap and you should gain so good numbers. I know a while ago in MM&FF mag on the "project icebox" they did a patriot stage 2 head swap on a procharged 200 GT and got like 104 or 114 rwhp gain
I would do LT's + catted X pipe... If you dont feel like dealing with LT's... then just get a catted X-pipe, your stock midpipe is hurting you... The advantage of LT's is you may only gain a little over 10rwhp... but you also lose about a pound of boost in the process... because your manifolds are so restrictive... less restriction = less boost.
LT's FTW!
after that you will probably need a powerpipe... Not gonna garauntee 400rwhp... but you would be close... you will probably have to do a pulley swap + new tune to make that kind of power... (you will need a new tune after any of these mods)
LT's FTW!
I just ordered a 3.4 pulley prom procharger on thursday. The tech told me that it should bring me up to about 9 psi on my setup. I can't wait. The only reason I haven't swapped out the midpipe is cause I'm debating on LTs. If I ever move back to California or an Emissions controlled area, LTs aren't something I want to have to swap back.
