Cam specific
vt engines.com
Any cam has potential for ptv issues if not degreed properly. Comp XE-270AH will work with the stock heads 1800-5800 rpm and you'll need new springs. 278s would not work. Not sure how much lope the 270s will give you.
vtengines is a very respectable company. Worth looking into.
ORIGINAL: cammed99gt
Here mine with stage 2 cams.It will give u a idea of what stage 2 sounds like.First video is with flow master exhaust and the second one is slp loud month
http://videos.streetfire.net/video/d0bdc98f-b3c3-4659-89b4-98cb0083abe9.htm
http://videos.streetfire.net/video/0...f70106d321.htm
hey bro what kind of stage two's are those? They sound pretty good? What all did you have to change to accomidate the cams? also what was your exhaust set up in the first video i liked it better?
thanks
thanks
That was with bbk lt's and there matching x-pipe both video's and the cams are from patiots.I have the stage 2 heads and cams from them.Got both for $1795 shipped to my door.
And the first video was with welded in flow master
thanks bro, so with those stage two's you dont have to worry about piston clerance? Also did you have to have a custom tune done when you put those cams and heads in? Whats the web site for patriot if ya dont mind?
ORIGINAL: 2002GTAUTOVERT
Stage 2's will run kinda crappy even with a tune without head work.. i suggest at least a Port job
+1 on vt cams.Check out there stage 2 cams.Very lopy and works with your stock motor
ORIGINAL: yelw02GT
check out VT cams
check out VT cams
The only bad thing about a 2 is that it make slightly more peak (even on stock shortblock/heads) but doesn't pick up as early as a stage 1.
ORIGINAL: ThisIsMyStang
Did you put those on your stock motor or was other things needed to have them? Also how much was the installation for both?, or did you do it yourself?
Yea i put them on my stock motor and u dont really need anything else.The person that did mine went ahead and got new head bolts plus gaskets and liftersbut thats about all.I think with everything including the oil,spark plugs and labor was around $7xx but i think that pretty cheap though.Dont know if u can find someone that cheapin your area.
