Cam specific
Old Jul 26, 2007 | 05:59 PM
ROUSH1981's Avatar
ROUSH1981
Default Cam specific
Ok done some research and cant seem to narrow it done to which cam i can use in my 03 gt that will give me a rough idle and i dont have to worry about piston clerance. I even talked to the guys from comp cams and he had a cam that would give me a rough idle but he said that he couldnt gurantee that my valves wouldnt hit my pistons. I really want a rough idle and know i have to get springs as well. So, any cam that i can have the best of both worlds of the rough idle and not worrying about piston clerance? Thanks guys!!!!!My car currently has just for the record:
Accu fab throttle body and plenum
cold air intake
diablo programmer or chip
4:10 gears
bassani high flow H-pipe
magna flow cat back
30lb injectors
Old Jul 26, 2007 | 06:05 PM
yelw02GT's Avatar
yelw02GT
Default RE: Cam specific
check out VT cams
Old Jul 26, 2007 | 06:18 PM
cammed99gt's Avatar
cammed99gt
ORIGINAL: yelw02GT
check out VT cams
+1 on vt cams.Check out there stage 2 cams.Very lopy and works with your stock motor
Old Jul 26, 2007 | 06:26 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
ORIGINAL: cammed99gt
ORIGINAL: yelw02GT
check out VT cams
Stage 2's will run kinda crappy even with a tune without head work.. i suggest at least a Port job
Old Jul 26, 2007 | 06:37 PM
cammed99gt's Avatar
cammed99gt
With no head work u can hit 280-290rwhp with camsand if u want to spend a lot more money on head work
($1,000+) for 15 or 20 hp then go for it
Old Jul 26, 2007 | 07:23 PM
ROUSH1981's Avatar
ROUSH1981
Well im not overly concerned with the hp gain, im seriously just wanting the rough idle sound. Thats all. And i googled Vt but everything it took me to said dicontinued???? Thanks for the reply's though guys. So my car will run rough (as in not good)if i use the just the stage 2 even with a tune? And when you say tune do you mean lap top tune? If sowhats the average price for a lap top tune? Thanks again!
Old Jul 26, 2007 | 07:29 PM
cammed99gt's Avatar
cammed99gt
No i think he means a hand held tuner or a dyno tune with a chip.Any where from $300-400 to $500-600
Old Jul 26, 2007 | 07:38 PM
cammed99gt's Avatar
cammed99gt
Here mine with stage 2 cams.It will give u a idea of what stage 2 sounds like.First video is with flow master exhaust and the second one is slp loud month
http://videos.streetfire.net/video/d...cb0083abe9.htm
http://videos.streetfire.net/video/0...f70106d321.htm
Old Jul 26, 2007 | 07:39 PM
ROUSH1981's Avatar
ROUSH1981
Wouldnt it be better to have a lap top tune done with those cams? And any ifo on where i can see these VT cams?
Old Jul 26, 2007 | 07:41 PM
cammed99gt's Avatar
cammed99gt
vt engine.com i think
