Removing Spring Isolators
Old Jul 28, 2007 | 01:33 PM
jmac72187's Avatar
jmac72187
corner carver
Default Removing Spring Isolators
I have FRPP C springs in the rear right now.
How much lower would the rear be if I removed the Isolators?
Will it make noises if I remove it?
Old Jul 28, 2007 | 01:43 PM
dsg04gt's Avatar
dsg04gt
Default RE: Removing Spring Isolators
It probably won't really be noticable from an appearance point of view. The rear has only one isolater as I remember, and I replaced all of mine with the Polyurethane ones. The one in the back is pretty thin and on the bottom, and since it's the stock rubber one its probably a little worn anyways.
Old Jul 28, 2007 | 02:33 PM
jmac72187's Avatar
jmac72187
corner carver
Will it effect my handling at all or should I just get some poly urethane ones?
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
mungodrums
Sep 28, 2015 10:54 PM
