Header problem
Old Aug 31, 2007 | 03:04 PM
Dragonus18's Avatar
Dragonus18
Default Header problem
i just got some long tube headers and a high flow X-pipe installed and for some reason after the installation my car tends to turn off now on it's own when my RPM's are low I notice. Does anyone know why this is happening? Anyones help would be greatly appreciated.
Old Aug 31, 2007 | 03:38 PM
yelw02GT's Avatar
yelw02GT
Default RE: Header problem
need a little better discription of the problem..does it stall out you mean?
Old Aug 31, 2007 | 03:45 PM
Dragonus18's Avatar
Dragonus18
Yes
Old Aug 31, 2007 | 03:53 PM
yelw02GT's Avatar
yelw02GT
did you jack the motor up? i know when i did mine i jacked my way the hell up so i had to disconect my intake and when i put it back together i had a gap near the MAF and i had a little stalling problem like that, check vac lines too
Old Aug 31, 2007 | 03:57 PM
Dragonus18's Avatar
Dragonus18
They did have to jack the motor up. I'm still learning about motors so can you please tell me what are the vac lines?
Old Aug 31, 2007 | 04:01 PM
yelw02GT's Avatar
yelw02GT
on your intake tube, check down buy the plastic peice that is between your airfilter and the tube,it has a connector running into the side of it, thats your MAF, make sure there are no gaps and everything lines up nice, as for your vac lines, any of the lines that run into your trottlebody make sure nothing is disconnected or has a cut or frey in it
Old Aug 31, 2007 | 04:03 PM
Dragonus18's Avatar
Dragonus18
Will do. THANK YOU VERY MUCH!!!!! : )
Old Aug 31, 2007 | 06:57 PM
Dragonus18's Avatar
Dragonus18
I found out that my dumb @$$ mechanic snapped off a hole in my MAF to the point where the screen is showing on the inside. Apparently when this idiot lifted my engine he wasn't paying attention and broke it. He also left a tool in my engine which I just discovered only minutes ago. Talk about superior service. I'd take the opinion of any person who knows how to work the system and raise hell at the same time so I can send these guys to the $#@! heap where they belong.
Thank you everyone for being so informative and helpful.
Old Aug 31, 2007 | 07:25 PM
Jbauer's Avatar
Jbauer
Tools left in engine bays are quite common, most mechanics love there tools, he'd be very glad to have it back.
I'd go to the shop and demand a new MAF.
Jb145700
Aug 21, 2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
