cam
Old 09-09-2007, 10:44 AM
smokinv6
smokinv6's Avatar
Default cam
i am looking and changing my cam while i got the engine apart and i am wondering what would be the best one... do i have to degree any of them, if so which one? i have a 2000 gt with full intake, exhaust and pullies. gears will soon be following.
smokinv6 is offline
Old 09-09-2007, 12:51 PM
droptoppony
droptoppony's Avatar
Default RE: cam
you have to get more then 1, and you should degree any set you install.
check out www.vtengines.com
droptoppony is offline
Old 09-09-2007, 01:09 PM
smokinv6
smokinv6's Avatar
Default RE: cam
what is the easiest way to degree your cams
smokinv6 is offline
Old 09-09-2007, 04:10 PM
2000GT4.6
2000GT4.6's Avatar
Default RE: cam
With the questions your asking you have absolulty no business trying to do a cam swap. It is involved and complicated, espcially if you do not have previous modular motor experence.
Go to a shop to get them installed, unless nothing else is done to your car. If you are just starting off, get some boltons first (gears, exhaust).
Edit; You can't just mess with/change one cam. The SOHC design has one cam per cylinder bank... having one cam degreed different or different profiles would simply not work.
2000GT4.6 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: cam
