need help with wiring diagram
Old Sep 23, 2007 | 02:03 PM
jcpower's Avatar
jcpower
Default RE: need help with wiring diagram
cliffyk from where you got that diagram, i will like to buy that book
Old Sep 23, 2007 | 02:18 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It's from the factory service manual DVD, from eBay, as I indicated in an earlier posting...
Old Sep 23, 2007 | 04:48 PM
jcpower's Avatar
jcpower
great,i will do that them, also i check with you information and i couldn't find the switch but the blower is working if that answer that problem,also remember that the fan is not working either.
Old Sep 23, 2007 | 06:02 PM
contentsunderpressur's Avatar
Ha, thanks Cliff, so it could be the switch.
Old Oct 6, 2007 | 02:34 PM
jcpower's Avatar
jcpower
wiiring diagram section of the DVD is not working because an error 250 or 350 any ideas cliffyk, everything else work
Old Oct 7, 2007 | 07:06 PM
jcpower's Avatar
jcpower
i bypass the conector that goes to the AC cycle switch and the fan turn on, the AC compressor still off, so any body please anyideas why the fan would work when I used the wired to bypass the conector and also any body has the layout for the fuse box bellow the steering wheels, thank you for looking
Old Oct 7, 2007 | 08:43 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: jcpower
[/align][/align]It sounds as though the DVD did not get burned properly--I'm sure the vendor will send another...[/align]
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
