dimmer switch?
Old Sep 23, 2007 | 05:41 PM
smokinv6's Avatar
smokinv6
Default dimmer switch?
I just installed a new cd player and when i went to drive it the other day the instrument cluster and climate controls did not light up. Checked fuses and fuse 37(adjustable illumination) was blown. Replaced it and blew right away. Is there any certain place to look or just look for a burnt wire going to the headlight switch? ive checked the radio again and it all seems wired right. its a 00gt vert if it matters
Old Sep 23, 2007 | 05:51 PM
MU71L4710N's Avatar
MU71L4710N
Default RE: dimmer switch?
well if it started happening after your cd player install i would pop the dash back off and start double checking connections. also try disconnecting the dimmer line for the new deck, perhaps its pulling too much power causing the fuse to blow. you dont even need to connect the dimmer wire anyways itll work fine without it, the radio wont dim with your dash lights tho (ionno bout u but ive never even dimmed my interior lights)
Old Sep 23, 2007 | 06:10 PM
smokinv6's Avatar
smokinv6
i dont believe the new radio even had the dimmer hooked up i will have to look at what wire that was again, i belive it was orange? but will look again
Old Sep 23, 2007 | 06:44 PM
contentsunderpressur's Avatar
Just unplug the new radio completely and put a new fuse in. If it doesn't blow then you've found your problem.
Old Sep 23, 2007 | 07:48 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
The dimmer rheostat's output passes through a 5A fuse, and then on to all the lamps that get dimmed--the wiresfeeding all these lamps (including the OEM radio)are light blue/red. [/align][/align]If this wire got shorted when the new head unit was installed, that fuse would go poof as soon as the lights go on...[/align]
Old Sep 29, 2007 | 12:42 PM
smokinv6's Avatar
smokinv6
ok just tried the new fuse without the radio and it didnt blow...can i just disconnect the blue/red wires going to the radio and will that fix it?
Old Sep 29, 2007 | 01:03 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
What connection at the radio is the blue/red wire going to? Most newer Jap radios have a yellow wire that should be connected to a always hot +12V source for the clock/memory, and a red wire that is the main power thatshould be connected to an ignition switched +12V source. [/align][/align]The blue/red wire from the car's dimmer should not be connected to anything--unless the radio has a pink/white (usually) wire.[/align]
Old Sep 29, 2007 | 02:05 PM
smokinv6's Avatar
smokinv6
ok there is no blue/red... is there a wire that can be disconected to keep this fuse from blowing all the time
Old Sep 29, 2007 | 02:22 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: smokinv6
ok there is now blue/red...
[/align][/align]Blue/red what? What color wire on the radio is the blue/red wire connected to?[/align][/align]
is there a wire that can be disconected to keep this fuse from blowing all the tie
[/align][/align]Yes. most likely the blue/red wire...[/align]
Old Sep 29, 2007 | 02:26 PM
smokinv6's Avatar
smokinv6
if i disconnect the blue/red by the dimmer switch then all the lights wont work...so which wire going to the cd player needs to be disconnected
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
jhawkr
Oct 30, 2015 01:55 PM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
