Pinging/Knocking
Old Sep 24, 2007 | 07:49 PM
pikuoff's Avatar
pikuoff
Default Pinging/Knocking
I just bought a SCT XCal2 with a tune from VMPTuning. I have a 2001 GT with just the JLT Ram Air Intake but I got it mainly to turn off the MIL indicator for when I put on my MAC Prochamber and CatBack. That and to give my car a little more "giddyup"
I am on my second tank of 93 octane so I figured it would be in the system enough to load my 93 octane tune. I do have more pep in the car but when I get on it, I am getting some pinging. It pings when I am at higher RPMs (4k+) or if I'm going 30 MPH in 3rd gear and give it some gas (basically floor it). Normal acceleration and cruising is fine.
Any thoughts out there as to what may be wrong? I figured I can rule out an exhaust leak since I haven't changed that yet and since it wasn't happening before I loaded the tune. The gas is from Exxon so I think it's good gas. The spark plugs are only about 2 weeks old and when I replaced them, the old ones looked fine. I'm not really sure what else to look for...
Old Sep 24, 2007 | 07:51 PM
97targa's Avatar
97targa
Default RE: Pinging/Knocking
I'd say your timing is too far advance at higher rpm's for the gas you have! You can turn down the timing for each rpms range I believe. Your timing should be least above 4k rpms!
Old Sep 24, 2007 | 07:55 PM
pikuoff's Avatar
pikuoff
Crap, I meant to post this in the tech section. Can a mod move it?
97Targa: Does that still apply if it happens at the lower RPMs like I mentioned with the 30 MPH in 3rd gear and flooring it? It's low RPM for that.
jagsfan
Jun 10, 2008 09:58 PM
RomanPacific
Jan 8, 2008 01:29 AM
5.0HOBOMB
Jun 25, 2006 12:23 PM
bcc333
Mar 16, 2006 12:40 AM
