methanol kit
Old Oct 11, 2007 | 03:44 PM
Prochargerri's Avatar
Prochargerri
Default methanol kit
I was thinking about going with a methanol kit for my car. Does anyone know if the gains are worth the buck?
Old Oct 11, 2007 | 03:49 PM
only90s's Avatar
only90s
Default RE: methanol kit
ORIGINAL: Prochargerri
Gave me 48 more horse and that is with -20 washer fluid...not even a 50/50 mix
Old Oct 11, 2007 | 03:53 PM
Prochargerri
How often do you need to refill the kit and how much is for a gallon?
Old Oct 11, 2007 | 04:03 PM
only90s's Avatar
only90s
I am not a good source on that...My 5.0 is one of four vehicles I have so..I have only put about 1000 miles on it this summer after I installed the Meth...
Depends on how much boost you are running and how often you get into the Boost...it only gets used under boost...
Snow Performance says 12 Full Throttle 1/4 mile runs is how long a 2 quart bottle will last....
I use Winter Blend -20 degree washer fluid for like $1/gallon
Old Oct 11, 2007 | 04:04 PM
Prochargerri
Ok thanks for the help.
Old Oct 11, 2007 | 04:22 PM
josh.davis's Avatar
josh.davis
whats a methonal kit?
Old Oct 11, 2007 | 04:34 PM
sgtbraddick's Avatar
sgtbraddick
meth kit is methanol alchol and water mix used by injecting it into the air intake the water cools the air charge through evaporation and thje alchol also helps with cooling the air charge but they say it takes 93oct pump fuel to about 120oct.
Old Oct 11, 2007 | 04:39 PM
lizzyfan's Avatar
lizzyfan
Underboss
Check it out:
https://mustangforums.com/m_3430620/tm.htm
Any questions, PM me!
BTW, last time at the track made 5 passes used about 12oz of 50/50 mix!
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
