The MOD list
With the suspension set-up nearly complete, I finally put a plan down for the engine. Let me know what you think. List possible parts that might be better, or any seguestions, or anything that I am missing for a complete motor.
1. Patriot Performance Stage II Heads
2. VT Stage II blower cams - or - Custom Grind about equal to <--
3. P-51 Fox Lake intake w/ fuel rails
4. Accufab 75mm TB
5. SLP LT headers
6. SLP catted X-pipe
7. VORTEC SUPERCHARGER V-2 SQ
I plan to keep the stock lower end, t-45, and rear endas I plan to be in the 450-500HP range.
4. Accufab 75mm TB
5. SLP LT headers
they are gonna have to detune the crap outta your car to keep from exceeding 450rwhp! id also look into MPHs custom cams! if you want an intake that performs well but wont cost as much, id say the Hardballer would be a nice option to check out!
ORIGINAL: JJ03MustangGT
I plan on having two tunes one titled "the everydayer" the other "use this if you don't want your tranny anymore"
Yeah, I hear good things about the MPH cams.
ORIGINAL: H0SS302
why are you not gonna build your bottom end, whats the point of having all that crap if you cant use it to the full potential?
if you push your stock block past 450 your gonna blow that baysh up n e ways. so you might aswell build it. the heads are overkill imo if all you want is to max out your block. i think the charger tb plenum full exhaust and a cam will do the trick...without a 2g head bill..thats just my .02
ORIGINAL: H0SS302
ORIGINAL: GolfmanSpeck
sound advice. I think I would want to atleast change out to PI heads or maybe the FRPP for NPI.... I don't know... maybe I should rebuild the bottom end. With 130k I am not too worried about the crank, but those stamped rods i know are junk to begin with.
ORIGINAL: H0SS302
what everyone is sayin is that if you push 450-500 like you want to. your motor wont last a day without building the bottom end the smart thing to do would be take that money build up the shortblock then save up and do the parts listed above so you can put as much power as you want through it and not have to worry about being stuck on the side of the road
ORIGINAL: 97mustang17
