Need some dynamite @@
Old Nov 10, 2007 | 08:37 PM
  #21
Indy88colts's Avatar
Indy88colts
Default RE: Intake manifold replaced and not happy !
ORIGINAL: Zoie_daGT
Okay, dont worry about it, I had the same issue w/ my car. First, pull the plugs and clean out an coolant that may have leaked down to the plugs. You may be getting steam from them and causing a rough idle. Now, take the manifold back off. Clean everything up good and clean. You will want new gaskets IMHO. I got Felpro ones for me but, your call. The coolant hoses in the back of the manifold going to and from the heater core may be leaking. Those hoses leaked for me. I would check that out good. I ended up putting silocone on them to seal them up good. Now, install the manifold back and carefully and correctly torque the bolts down in the right sequence. Dont get down, I did this at least three times and now can do an intake manifold on a 4.6L like its my job. Good luck and feel free to pm if you have any other questions.
[align=left] [/align]
Thanks for the help man , I really appreciate it! What about getting the check engine light ? I didn't have this before the swap. As for the anti freeze in the plugs, i'm betting your right because I know there is some in there. You say the coolant Hoses, if I remember correctly , isn't there just 1 coolant house on the passenger side on the back of the manifold ? This is where my manifold was split more then half way down the tubing that the hose slides onto. Am I missing something here ? I'm off Monday and Tuesday , so i'll devote my time to getting her back on the road then. I appreciate it and i'll let you know how it goes.
Mark
Old Nov 11, 2007 | 04:20 AM
  #22
Zoie_daGT's Avatar
Zoie_daGT
There are two hoses. One goes from the manifold to the heater core, and one goes from the heater core to the manifold. They are right next to each other on the passenger side. You might want to try to see what error codes you are throwing for the CEL prob. You may have a vacum leak too. That may cause the CEL light to come on. good luck.
Old Nov 11, 2007 | 11:28 AM
  #23
BlackMage's Avatar
BlackMage
the MIL might have been the antifreeze in the plugs. try resetting your computer aftter you clean out all the plugs. (just disconnect the battery for like 15 min) as for the leak, just keep looking for it, try starting it up and let it run, then search around with a flashlight to see exactly where it is leaking from. when i put my manifold on it leaked between two of the plugs on the pass side right up front, but after liek 5 miles of driving the leak stopped and hasnt been there since. well g/l man!
Old Nov 11, 2007 | 06:20 PM
  #24
Indy88colts
ORIGINAL: BlackMage
Thanks, going to try it tomorrow and see what happens. I appreciate all the help guys.
Old Nov 12, 2007 | 01:28 PM
  #25
Indy88colts
Default Anybody got any dynamite ???!!!!!!!!!!!!!!!
Well put new plugs in and still running like **** and now antifreeze is leaking like a waterfall around the damn thermostat !
I give up !!
clustersnarf
Sep 8, 2009 11:56 PM
Michael7166
Jan 31, 2008 11:14 AM
LA1Z24
Apr 8, 2007 01:13 PM
silstangchic
Feb 28, 2007 10:08 AM
