Need some dynamite @@
Old Nov 8, 2007 | 05:14 PM
Indy88colts's Avatar
Indy88colts
Default Need some dynamite @@
Finished installing the new manifold today , fired it up the first time and the o-rings for the fuel injectors were leaking. Went and got new o-rings , installed them put everything back together. Fired it up a second time , everything seemed pretty good, idled nice , good throttle response and everything seemed good to go. Went around the block , heading down the road everything seemed good and then all a sudden it started running rough so I hurried up and brought it home, popped the hood and I see steam like something was getting burned off the motor, yep , coolant laying on the block under the manifold !!!!!! I torqued the manifold bolts to 18 lbs like the instructions said and not sure where it's coming from. Needless to say i'm not too happy and I couldn't get any physical help from anyone unless I paid them an arm and a leg !
Maybe i'd be better off driving the damn thing off a cliff !!!!!!
Old Nov 8, 2007 | 05:18 PM
PolozLX's Avatar
PolozLX
Default RE: Intake manifold replaced and not happy !
Its alright, Brother. Take a deep breath, go get another gasket kit and a 12ver. You'll get it!
Old Nov 8, 2007 | 05:20 PM
Prodigy17's Avatar
Prodigy17
If you drive it off a cliff make sure you get it on tape.
Old Nov 8, 2007 | 05:26 PM
jrherald420's Avatar
jrherald420
did you torque them in the proper sequnce???
Old Nov 8, 2007 | 05:28 PM
Indy88colts
the gaskets were pre installed onto the manifold, they are actually o-rings
Old Nov 8, 2007 | 05:29 PM
Indy88colts
yep, torqued them with the sheet right on the motor and yes I had it facing the right direction
Old Nov 8, 2007 | 06:46 PM
jrherald420
maybe it had to heat up a little bit to seat its self and it leaked have you tryed to re torque the bolts and try it again??
Old Nov 8, 2007 | 06:52 PM
SINISTER's Avatar
SINISTER
Dumb question, but did you clean the mating surfaces before you put it on?
Old Nov 8, 2007 | 09:22 PM
Indy88colts
ORIGINAL: SINISTER
Yeah I did , cleaned it good with carb cleaner and wiped it all down good
Old Nov 8, 2007 | 09:23 PM
Indy88colts
ORIGINAL: jrherald420
I was thinking the same thing but what about it running rough ? I seemed to be idling/ running good but that changed after I drove about 1/4 mile
