4.10 gears question
Old Nov 12, 2007 | 01:23 AM
mustanggtrider's Avatar
mustanggtrider
Default 4.10 gears question
(41 tooth ring & 11 tooth pinion), does that equal 4.10 so how many teeth are on 373. At the shop where im getting them i know i counted a little more then 40 teeth i just dont wanna be jipped. Thanks.
Old Nov 12, 2007 | 01:25 AM
MustangMan00's Avatar
MustangMan00
Default RE: 4.10 gears question
41/11 is 3.73....
Old Nov 12, 2007 | 08:28 AM
scfd524's Avatar
scfd524
My 4.10's, which unfortunately are still in the box, are 41 on the ring and 10 on the pinion. They could be other combinations if you have a larger pinion. Just divide the teeth on the ring by the teeth on the pinion. So in my case 41 (ring) divided by 10 (pinion) = 4.10. [/align]
Old Nov 12, 2007 | 10:49 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Here are the typical ring/pinion combinations for popular Ford 8.8" rear-end ratios...[/align][/align][/align]
Old Nov 12, 2007 | 12:11 PM
mustanggtrider
They are 4.10s after all and thanx for the help i just dont trust mechanics it said 3.73 he said they just put them in the wrong box. So now i know.
Old Nov 12, 2007 | 12:59 PM
MrChubs1's Avatar
MrChubs1
Just FYI, the Motive 3.90s are 43/11. 3.909 is what it works out to. This is why some companies call them 3.91s.
Old Nov 12, 2007 | 01:48 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: MrChubs1
[/align][/align]That would make them run a bit smoother, and reduce the tooth load...[/align]
Old Nov 12, 2007 | 06:35 PM
mustanggtrider
well they are installing the 4.10s as we speak
mtgldr
Feb 3, 2024 09:00 PM
Luke9222
Oct 22, 2015 11:55 PM
Mustangmalo
Sep 6, 2015 05:22 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
